585,938 active members*
3,682 visitors online*
Thread: 94 Sabre 750
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Re: 94 Sabre 750
    On the advice from the guys from Fives, I took the panel apart, and put conductive paint on the back of the keys to make better contact.
    Got it back together. When I power on, these four lights are flashing red, and all the lights on the front are flashing as well. Like it's trying to power up, but not.
    All wires were hooked back up where they go. There are a few contacts that are just sandwiched between the boards with just the screws to loosely align them.
    Anyone have any idea what I have going on here? Could those contacts not be aligned well enough?
    Sent from my VS988 using Tapatalk
  2. #22
    Hey, J-Rod10
    How did you get past the "HOST CONTROL INITIALIZATION"
  3. #23
    How did you get past the "Host Control Initializing "
  4. #24
    Dec 2021
    6
    Re: 94 Sabre 750
    how did you get past the host control initializing screen
  5. #25
    Dec 2021
    6
    Re: 94 Sabre 750
    how did you get past this
  6. #26
    Dec 2021
    6
    Re: 94 Sabre 750
    I am working with a Sabre 750 that booted up correctly at the shop I bought it from. Now that I have it wired here at home, I am having issues. It gets to the system startup page and all of the inputs pass. Then, it flashes "host control initializing" and doesn't go any farther. Does anyone have experience with this issue?
  7. #27
    Dec 2021
    6
    Re: 94 Sabre 750
  8. #28
    Mar 2008
    285
    Re: 94 Sabre 750
    850SX MMC Card Low-Battery:
    You can contact Cincinnati Tech Support at Fives-MSI with your Machine and Acramatic Control serial numbers.
    It appears that while the machine was shut down the SRAM Battery on the MMC board has died.
    You've lost the Machine Application Software (PMC, PLC), I-Sub & G-Sub Routines, Part Programs, Tool Data, Program Offsets, SYS COMM (System Parameters), MTB COMM (Machine Tool Builder Parameters), Servo Parameters, RS232 Device Parameters.
    To get the Board repaired we would need the MMC Card Part number listed in the "Blue" Configuration Manual (three ring plastic binder) with Board Part numbers;
    Software Loaded, Control Options Enabled, SYS COMM & MTB COMM Parameter listing and Servo Parameters and Device Parameters.
    Without the "Blue" Configuration Manual (three ring plastic binder) you may have a major problem...
  9. #29
    Mar 2008
    285
    Re: 94 Sabre 750
    It sounds like you need to do the Panel Definitions which map the Softkeys into physical and logical inputs. You can contact Cincinnati Tech Support at Fives-MSI with your Machine and Acramatic Control serial numbers.
    they can provide this information to you by email.
Page 2 of 2 12
  1. CNC Sabre 408 Help - Bit Slipping
    By HolyDiver603 in forum USA Club House
    Last Post: 09-23-2016, 03:28 PM
  2. gerber sabre 408
    By nipon in forum Community Club House
    Last Post: 11-10-2013, 07:03 AM
  3. Sabre 500 With TNC 415 control
    By petesurrey in forum Cincinnati CNC
    Last Post: 08-14-2013, 04:56 PM
  4. SHOP SABRE
    By F&S in forum Waterjet General Topics
    Last Post: 03-10-2011, 03:56 PM
  5. Sabre 500
    By doctordemo in forum Cincinnati CNC
    Last Post: 11-17-2008, 06:02 AM
