585,992 active members*
5,404 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Convince me (not) to buy a G540 for my Taig
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Jan 2010
    50
    Quote Originally Posted by sclelectronics View Post
    No. I have a bus-strip for the neutral and Hot lines.
    So I run lines from there to any needing 12O Vac.
    Also I use single point chassis Ground inside the box too!
    Hth, Stuart
    Hi I'm really interested in how you wired this. I'm not super knowledgeable on electronics but I want to make a nice enclosure for a g540 with one switch.
  2. #22
    Aug 2005
    1092
    Quote Originally Posted by blake374 View Post
    If you are looking for ideas on a nice case, this is how I layout the back panel for the controllers I built and sell. They can be fitted for the UC400ETH as in this case or the Warp9td Ethernet SmoothStepper, Mesacard 7i92.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  3. #23
    Jun 2011
    68
    Re: Convince me (not) to buy a G540 for my Taig
    This was a very straight forward wiring setup.....
    From the AC-In receptacle..
    The hot line was routed to the face panel fuse holder.
    Then the Hot and Neutral lines were wired to the main Power rocker switch
    From the switch the Hot and Neutral lines each was wired to a Screw down style Bus Bar
    Now from the bus bars, I ran lines to the 2 small(5Vdc & 12Vdc)pwr supplies.
    Next I ran Hot and Neutral line into a relay. This relay is being controlled by the Emergency Power Down button!!!
    From the relay, the Hot and Neutral line are run to the 48Vdc main pwr supply and the Power outlet going to the Spindle motor!
    This translate, if the Emergency Cutoff switch is pushed, the Power going to the Gecko controller and Spindle are the only ones that are shut down!!
    So the Smoothstepper is still able to communicate!!!
    Hth, Stuart
  4. #24
    Jun 2011
    68
    Oops I forget to mention....
    All grounding from the AC Input, Output, to All Power supplies, and controls..
    They connected to a single Point in the chassis!
    To eliminate the Possibility of Ground Loops!!
    -Stuart
Page 2 of 2 12
  1. Taig and Gecko g540 wiring questions
    By NicolasArg in forum Taig Mills / Lathes
    Last Post: 04-29-2016, 05:58 PM
  2. Need to borrow a part, to convince my boss to buy
    By The Wolf! in forum Haas Lathes
    Last Post: 01-18-2013, 07:35 AM
  3. CNC machine, How to convince your wife
    By Sramtheman in forum Videos
    Last Post: 11-27-2012, 08:27 AM
  4. Z stepper recommendation - Taig, G540, 48v
    By jim_stoll in forum Gecko Drives
    Last Post: 09-03-2012, 06:05 AM
