585,712 active members*
4,258 visitors online*
    May 2016
    12
    PSG612 Z Accuracy Improvement
    I don't post to forums very often, tho I do read here all the time. There is loads of good info on the Tormach forums here at cnczone and I thank you all for that. So it's time I repaid with a contribution. Excuse me if this has already been done by anyone.
    I bought the PSG612, because I wanted to do precision grinding. The Z-axis downfeed is so mushy. I can move it down .0005, give it a tap on top of the column with my hand, and it goes down another .002 - .003 . Not good ! I checked backlash and the few other adjustments that are possible on this machine. Nothing changed.
    Started to wonder if maybe the counter weight was making the Z column 'float' in the space of backlash. I moved Z all the way to the bottom of its travel and re-installed the bolts the lock the counter weight in the shipping position. Wow, what a difference. I can still make it move down about .0005 with a hand tap on top of the column, but I think that's acceptable. Moving Z up without the counter weight isn't that difficult.
    I'm making a set of parallels, After checking them with a Starrett .0005 Last Word, I can't detect any measurable variance in height after making this one little mod.
    Oct 2005
    21
    Re: PSG612 Z Accuracy Improvement
    Quote Originally Posted by timbee View Post
    So your hunch was correct? Did you essentially disable the counter-weight? I don't have a grinder so I'm not familiar how it works, but I am considering getting one so I want learn as much as I can about maximizing its performance.
    May 2016
    12
    Yes, the counter weight is intended to make it easier to raise the z column. I disconnected the counter weight, it made all the difference in the accuracy of the machine.
  1. I put ballscews on my X2, no improvement
    By bmurph in forum Benchtop Machines
    Last Post: 09-08-2012, 04:01 AM
  2. $30 RPM Improvement for LMS3900
    By GG67 in forum Benchtop Machines
    Last Post: 04-02-2012, 02:41 AM
  3. Design accuracy to mechanical accuracy
    By kbayram in forum Linear and Rotary Motion
    Last Post: 08-18-2010, 09:34 AM
  4. NM-200 production improvement
    By robben678 in forum News Announcements
    Last Post: 12-29-2009, 04:53 AM
  5. Accuracy determination & accuracy improvement
    By rweatherly in forum DIY CNC Router Table Machines
    Last Post: 08-11-2005, 02:37 PM
