584,850 active members*
4,199 visitors online*
Results 1 to 8 of 8
    Jun 2009
    110
    "RUN FROM HERE" Z- Axis goes to Limit switch???????
    I have been running Mach 3 for years and sometimes I need to stop during a cut process or may get a false Limit trip. So I will deal with my issue and use the "RUN FROM HERE" feature and away I go! So sometimes I have had the issue when using this feature and I hit "Cycle Start" the "Z"- Axis for reasons I do not understand will travel up to Max travel and hit the Limit switch. Can someone tell me why this is happening and how to stop this?
    Steve in Maine
    Nov 2012
    1267
    Re: "RUN FROM HERE" Z- Axis goes to Limit switch???????
    In my experience, stopping and resuming a program in Mach3 is pretty much playing Russian roulette. Most of the time it works, but sometimes it just blows its brains out.
    It might have something to do with your Safe Z settings.
    Quote Originally Posted by CitizenOfDreams View Post
    That's my experience as well. I did it a hand full of times the other night, on the last try the table when the wrong way at restart and hit the Y axis limit. The first few times it went well.
    Jun 2010
    4252
    It has never worked for me. I don't try it now.
    Cheers
    Roger
    It's worked fine for me every time I've ever used it.
    Might be an ESS issue, as I use the parallel port.
    Sep 2005
    1740
    Thats one of the reasons I switched to Mach4, 3 has those little quirks. Its Not Warp9 ESS as it does great on 4.
    Just because it works in Mach4 does not mean it works in Mach3. Two different programs, with different plugins and firmware for each.
  1. Location of "x" axis overtravel limit switch on Arrow 500
    By Joe Miranda in forum Cincinnati CNC
    Last Post: 04-20-2015, 03:56 PM
  2. "limit switch triggered" aleatorio en Mach3, Ruido?
    By lamartinada in forum Spanish
    Last Post: 11-20-2013, 07:28 PM
  3. Replies: 3
    Last Post: 09-30-2013, 08:55 AM
  4. X2 - Best "Limit Switch" mounting locations?
    By CNC74 in forum Benchtop Machines
    Last Post: 02-04-2010, 10:20 PM
  5. "Test this axis/Run", and a limit switch
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 01-31-2010, 12:08 PM
