I am using hall effect homing switches. They are all 12V, with a 12v output signal. My input board is a smooth stepper, that only wants to see 5v, I have a circuit I can wire up to use this directly, but I was thinking of using relays.
I was thinking about using 12V relays, and wiring it so that the output would be 5V ttl.
If I use relays is the switching time of a relay consistent enough that my homing will be consistent?
I'm only looking for around .005" of accuracy from the machine. But all inaccuracy adds up, so my goal is to do the best I can at each stage.
