585,589 active members*
2,906 visitors online*
    Feb 2018
    15
    Speeds and feeds in GCode?
    So when I set up my RPM and IPM in vcarve is that whats actually being used when cutting?
    Were using a shop bot, and the guy who primarily will be operating it was telling me it was running 2k RPM faster than what I had programmed it to in Vcarve.
    So is it in the GCode? or is it on the machine side with shopbots software or something?
    Nov 2012
    1267
    Re: Speeds and feeds in GCode?
    G-code tells the machine how fast it should go:
    M3 S5000 (Turn the spindle on at 5000RPM)
    G1 F100 X22 Y33 (Go to X=22 Y=33 at 100IPM or 100mm/min)
    The machine will generally obey the G-code unless:
    - It is not capable of going that fast or that slow.
    - The spindle controller is not accurate enough.
    - The user has changed the speed with "override" controls.
    Shopbot code will look a bit different, but should still have the rpm in it.
    If the shopbot code has the right speed, then the issue is somewhere else.
  1. Feeds and Speeds DOC Gcode
    By kNucklBustr in forum Benchtop Machines
    Last Post: 10-01-2015, 05:19 PM
  2. Speeds and feeds
    By SMW81 in forum MetalWork Discussion
    Last Post: 08-04-2014, 10:39 PM
  3. feeds and speeds
    By thurminator in forum CNC Swiss Screw Machines
    Last Post: 02-13-2014, 04:16 PM
  4. Speeds n Feeds
    By jessbussert in forum WoodWorking Topics
    Last Post: 06-12-2008, 05:09 PM
  5. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
