585,987 active members*
4,304 visitors online*
    Apr 2017
    8
    Question Best approach for gantry lateral
    What do you think is better: use a 1 inch thickness aluminum plate with no reinforcement, or use 3/4'' plate with that lateral reinforcement (even it saving 1 kg on each side)?
    Obs: I will glue it with epoxy as the gantry.
    Re: Best approach for gantry lateral
    With the V Bearings you are using, it doesn't matter. The bearings will allow more movement than the gantry sides.
    Apr 2017
    8
    straightness tolerances as tight as +/- 0.001 in. for v-rollers according to BWC.
    Apr 2004
    5737
    That spec doesn't mean that every implementation using those rails and wheels will be restricted to +/- .001" movement at all points. That's determined by the structure of whatever you're attaching to them. The weakest links in your system will cause the most flex. Those are not likely to be the 1-inch thick aluminum gantry plates, as Ger points out.
    Andrew Werby
    Website
  1. 4 axis cnc - lateral movement is it possible?
    By cncspadeto in forum WoodWorking Topics
    Last Post: 09-19-2014, 03:19 PM
  2. Proximity lateral vs head on
    By ekcourter in forum CNC Machine Related Electronics
    Last Post: 09-13-2013, 02:17 PM
  3. Proximity lateral vs head on
    By ekcourter in forum Mechanical Calculations/Engineering Design
    Last Post: 09-13-2013, 02:08 PM
  4. milling lateral forces???
    By MaddCow in forum Uncategorised MetalWorking Machines
    Last Post: 05-31-2013, 12:55 AM
  5. RFQ: Lateral Control Arm
    By Durandal in forum RFQ (Request for Quote)
    Last Post: 02-17-2012, 01:40 PM
