585,712 active members*
4,086 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper rails not working. Need help.
Results 1 to 8 of 8
    Mar 2018
    4
    Hello,
    Im a hobby photographer in The Netherlands.
    Im making a simple setup to move 2 stepper rails on the X and Z with only buttons and no computer.
    I have bought cheap components in China. Im not a electronic specialist so i bought a compleet cnc board and i not want to work with computer or arduino or so.
    The components i use i attached as photos.
    Im almost sure i attached the motor the right way to the motor driver. But im not sure if the wires from the driver are connected good with the control board.
    The drivers i powered with a 12v 5a adapter. The board i power up by USB cable.
    When i put the power on the system the drivers both will show a red light. The control board is powered up and reacts on pushing the buttons on the remote. And when i power up i hear the motors react. But with pushing the buttons on the remote the motors don't react. What did i do wrong?
    I just want it to work with pushing the buttons on the remote! No PC or so needed.
    Greetings Arwin Lubbers
    Attached Thumbnails Attached Thumbnails 20180331_001953-1008x756.jpg   20180331_001920-756x1008.jpg   20180331_001904-756x1008.jpg   20180331_001846-756x1008.jpg
    Nov 2012
    1267
    Re: Stepper rails not working. Need help.
    Try this:
    XN goes to EN-, DIR- and PUL-. This is the common.
    XD goes to DIR+. This is the "Direction" signal.
    XS goes to PUL+. This is the "Step" or "Pulse" signal.
    XE goes to EN+. This is the "Enable" signal that turns the stepper drive on.
    Mar 2018
    4
    Hello,
    Thank you for the response.
    How must i do it to wire it from XN to the other three ports?
    Nov 2012
    1267
    Just loop short pieces of wire from EN- to DIR- to PUL-.
    Mar 2018
    4
    Yes that was it. Thanks a lot. I will post a picture when im done for the people that likes that.
    Nov 2012
    1267
    You are welcome. Sure, post some pictures of your project.
    Mar 2018
    4
    Hello,
    Is it possible you can tell me whitch motor cables i must switch to reverse the direction?
    Nov 2012
    1267
    Switch A+ with A-.
    (Or switch B+ with B-, the result would be the same.)
  1. Stepper Motors not working Please help
    By emh114 in forum Stepper Motors / Drives
    Last Post: 01-14-2016, 02:50 AM
  2. Smooth Stepper Working!
    By jimglass in forum Mach Software (ArtSoft software)
    Last Post: 10-07-2013, 03:05 PM
  3. Will this combination of rails, ballscrews, stepper motors and controller work?
    By joel0407 in forum DIY CNC Router Table Machines
    Last Post: 06-21-2012, 04:19 PM
  4. Stepper motor dissasembled, now not working
    By saberforge in forum MetalWork Discussion
    Last Post: 01-06-2012, 05:50 AM
  5. Stepper not working with G540, HELP!
    By Rotax91 in forum DIY CNC Router Table Machines
    Last Post: 11-13-2010, 11:14 PM
