585,759 active members*
4,238 visitors online*
    Aug 2016
    32
    Conventional milling
    I have been working my way through "SolidCAM 2016 Milling Training Course 2.5D Milling" and got to trying to machine the open pockets on page 157 of exercise 4. With difficulty i managed it but i can't get it to cut using conventional milling. It always opts for climb milling.
    How do i change from climb to conventional?
    I tried to upload the model but it's not a valid file format so here's a screen shot.
    Oct 2016
    23
    Re: Conventional milling
    With imachining, under the technology tab there's a drop down box for cutting direction. On normal pocket operations,on the technology, then contour tab there's a selection for direction. With the profile paths you can just select the tool side on the technology tab.
    Aug 2016
    32
    Changed to the pocket option and this solved the problem with one of my other posts and allowed conventional milling.
    Your reply was much appreciated.:cheers:
    Jun 2003
    1365
    To answer the original question on how to do it, when you select the geometry - you would want it to point the other direction, then under technology switch the path to the right instead of the left.
  1. Climb or conventional milling, which for which?
    By mecanico in forum MetalWork Discussion
    Last Post: 01-15-2015, 11:10 PM
  2. Needed: Offset belt driven milling head for conventional mill
    By Larry Callahan in forum Want To Buy...Need help!
    Last Post: 04-17-2012, 11:20 PM
  3. Thread Milling Climb versus Conventional
    By Geof in forum Haas Mills
    Last Post: 06-27-2011, 04:32 PM
  4. climb/conventional
    By juniormachinist in forum Mastercam
    Last Post: 06-03-2011, 12:07 PM
  5. Draw comparison between CNC and conventional lathe amd milling machines
    By fayysl in forum Uncategorised MetalWorking Machines
    Last Post: 12-19-2010, 09:47 PM
