THERMOCUT is a computer-controlled cutter which uses a titanium wire heated to a very high temperature (approx. 800 degrees Celsius). Hot wire technology allows cutting through many different types of foam. The digital control of working parameters with the possibility of creating your own material libraries results in cutting shapes with unique precision. Wide range of available finishing techniques allows creating illusion of different materials. Completed projects are well looked and not expensive.
With THERMOCUT you can cut any spatial object through different types of materials with density up to 60 kg/m3 and allowed to receive heat treatment like polystyrene, styrodur, polyurethane foams etc.
The ability to continue the cutting process after the cutting wire has been severed and replaced is a unique feature that saves our customers’ time and resources. Processing of large and complex projects may cause fatigue of the resistant wire, and may eventually lead to the wire being severed. Since the process can continue once the wire has been replaced, there is no need to restart the project and no source material is wasted. After replacing the wire, Coner ThermoCut continues cutting from the point it left off.
High cutting/movement speed 2800/7000 mm (110/275.5 in) per minute, respectively.
Rotational cutting. ThermoCUT cutters are supplied with a rotating table, which allows for creating revolved solids. The source material can be placed vertically or horizontally. The machine can create revolved solids of up to 3 m (9.8 ft) in size. The cutter is a functional equivalent of a lathe due to the smooth rotation of the source material simultaneous with motion along a predefined path.
Bi-directional cutting while the source material is rotated halves the processing time and supports open shapes.
Support for free-form (irregular) shapes. Using the advanced control software, you can load several different profiles (sections of free-form rotated solids) at the same time, and define the rotation angle between each pair of profiles.
3D visualization. Processing several profiles of free-form rotated solids may sometimes lead to unexpected results, since the cutting lines will overlap in 3D space. To save time and material, you can preview the rendered shape on screen.
Titanium wire. All Coner cutters are equipped with a titanium cutting wire as standard. The titanium wire is highly durable and permits higher operation speeds.
Multiwire machines. For several years our standard range of products has included multiwire cutters. Coner thermal cutters may be equipped with one or two arms, each holding up to 5 cutting wires. As a unique feature, Coner thermal cutter detects rupture of individual wires and continues processing from the point it left off after the severed wire has been replaced.
Custom-built machines. Coner will design and build thermal cutters according to size and specifications supplied by the customer. Custom-built machines can include any number of cutting elements. We can therefore deliver thermal cutters to satisfy our customers’ most exacting needs. CNC HOTWIRE FOAM CUTTING MACHINE
