ı need help, the machine doesnt work all buttons. just reset and shift are working.even the green lights of the order buttons do not light. ı check the fuse on relay card. it is okey. please help me
grab your multimeter and double check your NO(normally open) and your NC(normally closed)circuits do this check on all push buttons(switches) get your schematic and trace all runs to switches and check each (switch)push buttons,then start checking (overloads) thermal or timed, there is a short somewhere. Chinese machines are the easiest to work with.
Keysoftwareservice.com
Thank you, i will try tomorrow. One more thing, when i pressed the reset button 36770 values seemed. What does it mean ?
