585,737 active members*
4,581 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Problem with Madcam 6 Installation in Rhino 6
    Apr 2018
    14
    Folks: This is my first post on the forum so hope I am doing it correctly... I am trying to install Madcam 6, downloaded from the Madcam site, into Rhino 6. I have a student license for Rhino 6. I downloaded and installed RhinoCAM and installed it into Rhino 6 and it ran OK. I then installed Madcam too which installed but crashed Rhino multiple times. I then uninstalled RhinoCAM and tried to reinstall Madcam but go the error message "error loading - MadCAM.rhp". After multiplie uninstalls, reinstalls of Rhino 6 and MadCAM I still get the same error message. I have received no answer from the Madcam folks to my several emails so thought to see if anyone in this forum can help me. I am trying to evaluate Madcam but can not even get it to load correctly... Any ideas ?Thanks
    Feb 2018
    59
    Re: Problem with Madcam 6 Installation in Rhino 6
    you need to remove entries from registry "regedit"
    also remove all traces x86 common files
    -Keysoftwareservice.com
    Apr 2018
    14
    Sir: Thanks for your reply but I do not understand it. Could you explain? I am not a computer professional, but a woodworker trying to use a CNC router for school. Is what your saying perhaps related to trying to install Madcam multiple times, even though I uninstalled it several times and downloaded and installed a new version of Rhino?
    // JRS_CNC
    Feb 2018
    59
    i would try these things,,,,
    completely remove software from all instances, windows registry, program files /common folder or invest in an uninstaller, there is a trace of the program preventing
    just suggestions,,
    -keysoftwareservice.com
    Feb 2010
    10
    Hello,
    i got also a Problem with loading the madCAM Plugin.
    Try to start Rhino as Admin solved this Problem, but i cannot choose a machine, and got other option Problems...
    Rhino 6.3 - MadCAM Version 20180306
    Attachment 391856Attachment 391860
  1. Madcam seems to have gone from Rhino
    By AvB in forum MadCAM
    Last Post: 02-02-2014, 01:23 AM
  2. Rhino 5, MadCAM
    By rdjay in forum MadCAM
    Last Post: 03-05-2013, 10:36 PM
  3. rhino to madcam
    By daisydog in forum Rhino 3D
    Last Post: 07-31-2007, 07:15 PM
  4. Rhino + MadCAM
    By Bill.T in forum Rhino 3D
    Last Post: 10-27-2006, 06:12 PM
  5. madCAM, a 3D CAM plug-in for Rhino 3.0
    By JOM in forum News Announcements
    Last Post: 02-13-2006, 10:36 AM
