586,005 active members*
4,869 visitors online*
    CNC Room UB1 - VFD control
    Is it necessary to purchase the DC2DC-12V Module for the UB1 board in order to pass a PWM signal to the VFD??
    Re: CNC Room UB1 - VFD control
    Most VFD's don't accept a PWM signal.
    The UB1 converts the PWM to a 0-10V analog signal, and requires a 10-12V DC voltage. You can usually get the 10V from the VFD. However, there's a slight voltage loss in the PWM >0-10V circuit, so to get a full 0-10V range, you need a 12V supply. If you can't get 12V from your VFD, then yes, you need the 12V supply in order to get your 0-10V speed control output.
    Thanks Gerry!
  1. Still room for more!
    By cncadmin in forum EnRoute
    Last Post: 10-26-2011, 03:40 AM
  2. So how much room is 400m
    By Dancy in forum CNC Machining Centers
    Last Post: 12-21-2007, 07:53 PM
  3. CNC Room Computer
    By mikegris in forum Computers / Desktops / Networking
    Last Post: 07-18-2007, 09:48 AM
  4. Any plans for Sun Room?
    By wjbzone in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 02-16-2006, 01:33 AM
