585,970 active members*
4,457 visitors online*
Page 2 of 3 123
Results 21 to 40 of 42
  1. #21
    Apr 2018
    88
    Re: Optimum MH25V
    Hi Ian,
    Normally you are right. But I have found swarf mixed with the ACME leadscrew grease. Therefore definetly a full table + saddle disassembly and cleanup was necesary.
    And yes, this helped the measurement process needed for the CNC retrofit.
    In the end all was good, the bad parts will be replaced under the warranty andd soon I will be able to proceed with reassembly.
    A.
    Sent from my SM-A520F using Tapatalk
  2. #22
    Sep 2006
    6463
    Re: Optimum MH25V
    Best of luck for the rebuild,...…..I'll be watching to see the results......don't forget when you plan the Z axis stepper motor drive that you also need to take into consideration the extra weight of a power drawbar mechanism.
    Ian.
  3. #23
    Feb 2016
    58
    Re: Optimum MH25V
    I Hope they can sort it out for you, otherwise it pushes you a bit to install linear rails... I have seen a few guys get gibs made but I'm not sure if there are people who can do that locally for you
    Thanks for sharing your build, I am watching on with interest, I'm looking at converting a machine in the next 6-8 months. I also want to step it up as you have and get the machine under CNC then move forward from there. I've heard DMM 750w servos direct drive are a good match for a machine of this size/type.
    Which controller are you planning to use? I searched for SZGH but found a 3 axis grinding controller, the SZGH 990.
    I use a hobby CNC router with Mesa 5i25 and Gecko G540 under LinuxCNC, and find it very powerful and reliable, but a bit more work to set up. I think I will go LinuxCNC on my build.
    Keep sharing your progress!
  4. #24
    Apr 2018
    88
    Re: Optimum MH25V
    The parts are ordered and will arrive under warranty. So all will be sorted out, I just have to be patient.
    When I will make the conversion I will be using Delta 750 W AC servos. X and Y direct drive and the Z with 1:2 reduction. I still have to decide if the reduction is enough to prevent the head from lowering while not powered, or I need a brake.
    For the controller I plan to use 5 axis SZGH controller: SZGH-CNC1000MDcb-5 5 Axis CNC Controller For Milling Machining Center
    It is actually a 3+2 and I like the option to add a 4th or even a 5th axis in the future (if needed or even possible for this machine). Also it is not clear to me if using the ATC function all 5 axes are available for machining or 1 axis is repurposed for ATC. Therefore considering the price delta between 3 axis and 5 axis versions is not that dramatic I will get the 5 axis one.
    BTW: I checked the spindle inside taper concentricity with a dial indicator and is spot on. Could not get the dial needle to move while rotating the spindle by hand. Checked it in 2 places. Could not be happier.
  5. #25
    Oct 2004
    832
    Re: Optimum MH25V
    Quote Originally Posted by DLF View Post
    Also it is not clear to me if using the ATC function all 5 axes are available for machining or 1 axis is repurposed for ATC. Therefore considering the price delta between 3 axis and 5 axis versions is not that dramatic I will get the 5 axis one.....
    It would depend on how your tool change works. If it requires Step/Direction signals then I think it would use up an axis. If it just needs signals to rotate via relays (for direction) and other standard digital I/O then you would not need to use an axis.
    I have a 2 axis lathe controller which I hope to fit soon and although my lathes turret utilises a servo motor for rotation it does not require step/dir signals as I have an indexing servo drive. That means I only need digital I/O to position the turret and thus do not require a 3 axis control.
  6. #26
    Apr 2018
    88
    Re: Optimum MH25V
    Quote Originally Posted by Hood View Post
    Not really sure what signals are needed for the tool changer. The manual is available for download and contains a wealth of information but is written in chinglish and not all chapters are very clear. Therefore the 5 axis version seems to be the safe bet.
  7. #27
    Apr 2018
    88
    Re: Optimum MH25V
    Well... warranty is gone
    But central lubrication system mods are progressing just fine. Started today with the Z oil channels. Guideway channels are done. Tomorrow dovetail channel will be milled.
    Milling ongoing on a BP clone:
    Oil channels
    Side oil port
    On the other side one of the gib locking holes will be used.
    Question: how do I deburr the channel sides without also scoring the guideway surface?
  8. #28
    Apr 2018
    88
    Re: Optimum MH25V
    More milling done today. Added additional channels in the middle of Z guideway oil channels.
    And milled the Z gib. After all gibs will be done, I will have them reground.
  9. #29
    Apr 2018
    88
    Re: Optimum MH25V
    A little progress today.
    Milled the X axis oil channels. The rear facing dovetail needed a bit more love than usual because 2 horizontal oil channels had to be drilled + 1 vertical. The horizontal ones needed M5 threads to be tapped, especially the bottom one which had to be tapped for the whole length.
    M5 grub screws were installed to block the oil pasaages and guide the oil towards the dovetail.
  10. #30
    Oct 2013
    543
    Re: Optimum MH25V
    Nice looking work Mr...we did just about the same thing on the Grizz.
    Much later I happened on a thread on another forum that noted when you machine little slots for oil in the mating surfaces that they should be on a angle to the movement of the slide. The theory is if they're straight, the oil stay in the little trough and merely floats back and forth with the movement of the slide. If they are on an angle, the movement of the slide puts the oil troughs in a shear situation which forces the oil out into the clearance between the parts. I thought that sounded reasonable.
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  11. #31
    Apr 2018
    88
    Re: Optimum MH25V
    Quote Originally Posted by atomarc View Post
    Stuart
    Hi Stuart,
    I also thought that diagonal channels would force oil better between the sliding surfaces. This is the reason why I have milled the little cross channels.
    That being said, the milling is done on a BP clone manual mill located in a small-ish production environment. Therefore the available machine time is limited and milling diagonal channels required a more elaborate set-up which was time consuming (removing vise, clamping in different positions + re-installing and squaring the vise at the end of session). Instead a big vise was already installed and clamping in the vise and milling orthogonality made more sense.
    So, no crying over spilled milk. The oil channels are almost done at this point, so no going back possible anymore. How does the oiling worked out for your machine? Are you happy with the solution?
    On another thread someone stated his oil pump had enough pressure to lift the table a bit, enough to show on the surface finish when oiling was active during milling. If this is actually true then there would be no problem with oil distribution because oil will be squeezed between the sliding surfaces by the pressure alone. We shall see.
  12. #32
    Oct 2013
    543
    Re: Optimum MH25V
    The only piece oiled on the Grizz is the 'Y' saddle and the oiling system seems to works fine...it's too late for me as well, it's done and it works so no spilled milk here. I just thought it was an interesting concept on the part of the person that posted the theory of the angled oil slots.
    Stuart
  13. #33
    Apr 2018
    88
    Re: Optimum MH25V
    Oil pump arrived the other day. I just unpacked it and is big. Added a ruller for reference.
    4 liter oil reservoir, 140-200 ml/min @17-20bar pressure.
    No integrated timer. Just the motor connections, priming button and low level sensor. Control functions will be implemented in the controller.
  14. #34
    Apr 2018
    88
    Re: Optimum MH25V
    Motor housing with the electrical connection block.
    I am very pleased with the build quality.
  15. #35
    Apr 2018
    88
    Re: Optimum MH25V
    Made some progress with the oil grooves. Did one side of the Y.
  16. #36
    Sep 2006
    6463
    Re: Optimum MH25V
    Hi, very many years ago when I worked in a factory I refurbished the slideways on an old belt driven horizontal borer and the oil grooves were cut by hand with a cold chisel using a zig zag pattern all along the length of the slideways.
    Ian.
  17. #37
    Apr 2018
    88
    Re: Optimum MH25V
    Quote Originally Posted by handlewanker View Post
    Ian.
    Indeed, the zig zag pattern would have been ideal. I also saw such pattern on some older VMCs.
    On a CNC that can be easily milled. Chiseling is beyond my skill level and I do not want to experiment on my machine.
    Another approach I saw was milling a big Z or V shape groove along the guideway. I think this solution is the middle ground.
    But, because of practical reasons (limited machine time available) I chose the groove pattern shown in my pictures. Might not be the most efficient one, but it was done by others on similar size machines and it works.
    If I have to program the pump to start more often then I will just have more way oil consumption. Since I am doing this as a hobby it will not be the end of the world.
  18. #38
    Sep 2006
    6463
    Re: Optimum MH25V
    As the saying goes....all roads lead to Rome.
  19. #39
    Apr 2018
    88
    Re: Optimum MH25V
    True, true...
  20. #40
    Apr 2018
    88
    Re: Optimum MH25V
    Hello,
    I made a lot of progress with the mill.
    I finalized machining the gibs. Added dimples on the back side to accomodate ball ended adjustment setscrews. This makes gib adjustment super easy. I also had the gibs re-ground on both sides to ensure flatness.
    An oil flow restrictor had to be made to ensure proper oil flow to both the gib and the dovetail. This was made out of POM. The oil passage is 0.7mm in diameter.
    I also milled oil channels in the oposite dovetail.
Page 2 of 3 123
  1. Optimill MH25V CNC conversion
    By K_Jensen in forum RF-45 Clone Mill
    Last Post: 01-27-2019, 05:18 PM
  2. Any Optimum MH-28 conversions?
    By bmanners in forum Benchtop Machines
    Last Post: 06-29-2016, 02:56 AM
  3. Optimum BF 46
    By Kiwi 007 in forum Benchtop Machines
    Last Post: 09-03-2014, 10:03 AM
  4. OPTIMUM F45
    By MARTY FX in forum Benchtop Machines
    Last Post: 04-24-2012, 12:27 AM
