585,973 active members*
4,014 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Auto tool change position
Results 1 to 7 of 7
    Jan 2009
    9
    Hi guys,
    I have an Arrow 500 (Acramatic 2100) which crashed today. It looks like all the offset info has been lost.
    I have everything set back as best I can but now when there is a tool change in a program the machine rapids to a tool change position that is near to machine datum zero.
    If I 'data reset' before the tool change & start the program from the next tool change then it is fine & doesn't move.
    I've looked for a tool change position setting but can't find one.
    Any body help?
    Many thanks.
    Dec 2006
    584
    Re: Auto tool change position
    Not sure what you mean by " it's fine and doesn't move" , does it do a normal tool change?? Does it happen on just one tool or any tool?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Jan 2009
    9
    Quote Originally Posted by meckardt55 View Post
    Hi Mike,
    By its fine I mean it doesn't move in the x & y. It happens to any tool change in a program. MDI tool changes are ok.
    Sent from my SM-N950F using Tapatalk
    Dec 2006
    584
    Jan 2009
    9
    No, I'm using new and old programs that never used to have this issue either.
    Is there a default tool change position in x & y at I can change? I thought I read something about a value that if it was negative then it wouldn't move the x & y?
    Jan 2009
    9
    Any help, much appreciated!!!
    May 2016
    526
    It sounds like you've lost the G28 P4 position
    There is a section in the acramatic control showing you how to reset it
    Try looking at section 4 page 64
    Any problems inbox me
  1. Park & tool change position after tool probe.
    By Ozzybee57 in forum Mach Mill
    Last Post: 10-16-2016, 03:57 PM
  2. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  3. Replies: 2
    Last Post: 09-18-2014, 05:28 PM
  4. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
