I have a large CNC plotter that I built around five years ago that has been working at my canvas shop constantly without fail, but today it broke down and I would like some help troubleshooting the problem or perhaps someone out there has had a similar issue.
The Y axis suddenly started making a lot of noise in the middle of the path and would no longer move properly. It appeared at first that something was jammed in the track but quickly determined that the problem was not mechanical. After trying a few times moving it the x axis started having the same issue. Both the x and y axis have NEMA 34 stepper motors and the z axis has a NEMA 23. The Y axis is a larger motor. The z axis is still working properly. When I jog the machine it moves erratically and makes a lot of noise. Since it is two of the motors and they all run on independent drivers I can assume it is not the motors, drivers or wiring to them and likely the break out board, smooth stepper, power supply or Ethernet cable. I tested the power supply (not under load) and got slightly above 36v. Please help if you have any input on this!
Some info about the machine:
Mach 3 to
50'Ethernet cable to
Smooth Stepper Ethernet version to
G 10 Break out board (older version) to
Drivers for each Axis (CW230 and QJ8060) to
NEMA 23 (z) Nema34(X,Y)
