585,917 active members*
3,435 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Machine Feature not working
Results 1 to 7 of 7
    Jul 2008
    21
    we have got EdgeCam 2017 R1 at work, I tried to use Machine feature in machining but all that comes up is a dialog asking do you want to Rough, Finish or Both the feature, I aleady had a tool picked so ticked use this tool, when I press ok I am expecting Edgecam to ask me which feature needs machining but nothing comes up. I have already ran feature finder so all the features are there, so I am a little stumped now on what to do, has anybody any ideas?
    Dec 2008
    441
    Re: Machine Feature not working
    Hello!
    First off all i will recommend you to install the latest Edgecam version. 2018 R1 Service Update 5
    Here is a link to their software page, and if you don`t have, you must make an account. Maby your reseller need to help you with that. https://customers.verosoftware.com/S...eDownload.aspx
    In 2018 you have a new option that you can use in "Machine Feature". That option is "Use Current Tool"
    When you choose "Roughing", Edgecam only make a "roughing cycle". If you choose "Profiling", Edgecam only make a "profiling cycle"
    When you choose "Both", Edgecam make first a "Roughing cycle" then a "Profiling Cycle" afterwards. It depents on what you want to do.
    Do you got an error when Edgecam tell you to choose a feature?
    Remember, you don`t always need a feature, you can pick the solid.
    Hope you understand something
    Greetings from Robert!
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Jul 2008
    21
    after I click ok on selecting roughing option the dialog goes off then nothing happens, cheers for reply I will get latest update installed ASAP and let you how I get on
    Regards
    Dec 2008
    441
    Select roughing? are you now in rest rough in the roughing cycle?
    Dec 2008
    441
    Jul 2008
    21
    finally sussed it out, in settings in the launcher, the master strategy location was pointing in the wrong folder should be USER\themes\default\strategy now working perfectly, thanks for advice
    Dec 2008
    441
    Good that you find it out! Just ask if there is something i can help you with.
    Have a nice weekend!
    Greetings from Robert.
  1. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  2. Feature of CNC Machine ROCTECH
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 10-30-2014, 07:10 AM
  3. Help me understand the machine setup feature
    By sansbury in forum BobCad-Cam
    Last Post: 08-04-2013, 03:36 PM
  4. Replies: 8
    Last Post: 07-18-2012, 10:51 PM
  5. Cutter Compensation feature not working
    By CLSmachining in forum Machines running Mach Software
    Last Post: 05-27-2012, 12:22 AM
