585,763 active members*
4,398 visitors online*
    Mar 2018
    16
    3D scanning with two cameras
    I finally have the David 5 running with two cameras.
    And was able to calibrate the camera and the projector.
    Scan results not the greatest I have a screen print attached.
    If you look at the screen print it almost looks like the two cameras could not fuse the images together?
    Is this a problem with the cameras not aligned?
    Question on the calibration of the cameras do you have to do a calibration of the one camera view then also a calibration of the other camera view?
    w/o vids to watch flying in the dark
    Any comments would be great
    Please help.
    I didn't find the right solution from the Internet.
    References:-
    https://bit.ly/2HeekQR
    Business video animation company
    Apr 2004
    5735
    Re: 3D scanning with two cameras
    Did you try getting support from HP, who bought the David scanner business? Are they the ones who told you to use 2 cameras? The David systems I've seen only use one. Here's a setup guide, if you don't have it already: DAVID - DAVID 5 Manual
    Andrew Werby
    Website
    Feb 2007
    4553
    HP 3D STRUCTURED – LIGHT SCANNER PRO S3 DUAL CAMERA UPGRADE KIT
    Scan with complete stereo vision
    Make your HP Structured Light Scanner Pro S3 more robust and enhance its quality by attaching a second HP 3D HD Camera Pro to mitigate errors and produce higher-precision scans.
    https://www.growshapes.com/store/p83...-camera-bundle
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2004
    5735
    Thanks, Jalessi - at least we now know it's a thing. Doesn't it come with any support to make it work?
    Andrew Werby
    Website
