Internal Combustion engine (IC engine) is a spark-ignition engine. Normally, it is a petrol engine. In this type of engines, spark generated by spark plug is responsible for combustion of air-fuel mixture. But in Compression Ignition engines (CI engines) combustion process starts by the heat generated from compression together with the injection of fuel starts. These are typically diesel engine and it does not require external spark.
