585,951 active members*
3,894 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Artcam toolpaths profiling ( Along - Outside - Inside )
    Dear Friends
    i work now with Artcam and i can get the g code from this program for the xilog plus (xxl ) , i don't have any problem for this steps.
    Q: When i read the g code for toolpaths profiling ( Along - Outside - Inside )
    i don't find the c=0 or c=1 or c=2 .
    how can i add this command (c=0, c=1 , c=2 for example ) without any problem.
    also i need reference command book for xilog plus.
    please could you help me
    Re: Artcam toolpaths profiling ( Along - Outside - Inside )
    C=1 or C=2 is right or left, not inside and outside.
    You need to edit your post processor to add the C, but I don't know if ArtCAM supports G41/G42 (Which is what the C= is).
    The help file is the only reference I've seen for Xilog.
    thank you at first .
    but i think i read in xilog plus help that c=0 center c=1 left c=2 right but in artcam program i can do that
    normally.
    the worker in CNC machine has problem for do this job. he can not understand where is the naif exactly.
    because i need to add code to the post process for help the worker.
    i hope you are understand me.
    thank you again
