Hello all! I have an '06 VF3 that is throwing a 123 spindle drive fault alarm on startup and will not clear. I have read through several posts and I have checked these things that were suggested on other posts. I have 250v incoming power (tapped correctly for this amount) but on the drives DC Buss voltage I am only getting a 19.2vdc reading and the diagnostic page is showing 20vdc. The machine shows it should be in the 325vdc range and I am thinking that I read that somewhere also. Is this a Vector Drive problem? Thanks for any help you may be able to give!
