[Sorry, initially posted in an inappropriate section - MANY forums here!]
Hi all - first post but I have bought a pretty well sorted 6040 as an exercise to learn about CAM and various basic components of the process and I love it. Now I am wanting to build a MUCH stronger frame using linear rails and dual X axis screws etc. I'm looking at a lot of people's designs to get ideas and inspiration and I wanted to test a theory that I haven't found a good explanation for yet...
Most of the 6040 designs from factory have a very simple gantry design and quite a few of the people reworking them replace the gantry uprights to both increase the distance between the bearings (improves rigidity) and also lean the side supports back so that the spindle ends up being placed equally between the 2 bearings (when viewed form the side). Is this so that there's limited/no torsional forces on the gantry from Z movement? Obviously there will still be the major forces from the tool load as the gantry moves the tool into material - but is the Z loading significant or worth designing an offset set of supports? I have made a quick hand drawn picture to help explain. The blue is the Z axis and spindle, the red is a typical 6040 set of gantry side plates/bearings, and the green is the proposed offset gantry side plates and bearings.
If there are any resources covering some of the theory of frame and gantry design then I would love to hear about them, as well as specific replies to my question here. Even build threads that are well respected and exemplify good design approaches would be appreciated.
Regards
Neil Gardner
New Zealand
