585,761 active members*
4,163 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1400-5A vs 1400-5C CPU board
    May 2017
    4
    I want to run a RAM upgrade in my machine. I know the 4,8 and 16MB expansions works on a 1400-5C CPU board but not 1400-5A.
    Does anyone know what the differences are between these 2 revisions? Anyone had their 5A board upgraded to 5C?
    Sep 2009
    103
    Re: 1400-5A vs 1400-5C CPU board
    I have a 1400-5A with 4MB expansion. I never heard that the memory wouldn't work with the different revision letters. As long as it's a 1400-5, you should be good to go.
    Here's a compatibility chart; https://www.fadalcnc.com/media/pdf/A...patibility.pdf
    May 2017
    4
    Quote Originally Posted by Tedger View Post
    ITS are saying..."Also if you have a 1400-5A and want to use 4,8, or 16 meg memory then you need to upgade it to a -5C. We can do that for $95.00"
    https://itscnc.com/pcb-0030-p-165.ht...3565ba5bb66196
    Sep 2009
    103
    Well,I looked it up and you are correct. You can only use PCB-0041(384K) on the 5A .
    For the price people are charging for additional memory expansion. I would much rather purchase a calmotion.
    May 2017
    4
    The difference between 1400-5A and 1400-5C revisions is the crystal speed at U11.
    1400-5A = 50 mhz
    1400-5C = 48 mhz
    On a 1400-5A change the crystal to 48 mhz and 4, 8 and 16MB RAM upgrades will work.
  1. More blocks/sec from a 1400-5 vs. 1400-4?
    By mflux_gamblej in forum Fadal
    Last Post: 06-27-2017, 03:58 PM
  2. Replies: 0
    Last Post: 02-07-2014, 01:29 AM
  3. Anilam 1400 on Eagle 400
    By ts4tomh in forum Servo Motors / Drives
    Last Post: 05-22-2008, 06:01 AM
  4. 1100 and 1400 anilam cpu need new where to get
    By jetski in forum Milltronics
    Last Post: 11-27-2007, 06:22 PM
  5. 1400 watt UPS's
    By dneisler in forum CNC Machine Related Electronics
    Last Post: 01-22-2007, 03:20 PM
