585,702 active members*
4,015 visitors online*
Results 1 to 6 of 6
    Apr 2007
    52
    mazak 640m circular tornado milling cycle
    Has anyone tried this canned cycle to do thread milling? I'm just curious because it asks for pitch one which looks like a chamfer at the beginning of the hole and pitch 2 which is in the actual hole you are wanting to thread mill.
    Any help is appreciated. Thanks in advance!!!!!!
    Apr 2007
    17
    try this for thread Milling:Thread here is 1 1/16-12
    Describe tool as Tap in Tool Data Exp:--un17s/12
    In Size Box-- Enter the Dia of tool used
    Where it says Fixed!!! Change to Floating
    In Program:
    Describe thread cycle as a tapping cycle:
    UN Unit Nom Major Pitch Tap-Dep Chmf Chp
    (+) 1 Tapping un17s-12 1.0625 .0833 . 75 0 0
    sno tool No Hole Hole-Dep Per-Dia Pre-Dep Rgh-Dep
    1 cdrl
    2 cdrl
    3 Tap un17s-12 1.0625 .75 Planet .02 Fix P.0833
    Fig Ptn z x y
    1 Pt 0 1 2
    Now go and curser back up tp Unit1 Line
    Hit Right arrow Key and select TPC
    Change D49 to 0
    Should Put a (+)in front of Unit #
    This should work!
    Proven on M Pro:M Controls
    On mt pro par. is U63
    this info use provided by :Jim Stone 11/22/04 (guess Mazak)
    It did work for us! Be safe and run dry to prove
    If single pointing use Tornado
    I do have more info if you need it.
    Apr 2007
    52
    Thanks for the reply. I 'll give that a shot. Have you ever used the Tornado cycle?
    Apr 2007
    17
    Tornado Mill
    Here Is What I Understand About The Tornado. As Of Yet I Have Not Used It For Thread Milling. But I Have Used It Milling
    You Will Lose The Last Thread. Because It Makes One Arc Around The Bottom Before Pulling Out. From What I Seen Using Tornado Milling Cycle.it Should Be The Same.
    It Would Be Best To Start At Least .100 Above Cutting Point Due To Rapid Move.(starts At Center Od Bore And Rapids Out And Arc Into Cut)
    And Thread At Least One Thread Deeper Than Required.for The Arc Out At End Of Cyclce.
    Watch Out Off Clearance.
    I Will Try It Tonight! Try A Couple Diferent Cases Tonight.
    Apr 2007
    52
    Let me know what happens i'd really appreciate it! Thanks in advance!!!
    Feb 2007
    198
    tornado cycle
    I think you must call surface finish as "0", which is NOT A SOFTKEY!
    This forces all motion to be helical, even the pull out.
    any number other than "0" results in a 360 sweep at the bottom with Z axis fixed.
    Jim
  1. Colchester Tornado Fanuc 21i-t
    By Stebedeff in forum Fanuc
    Last Post: 11-08-2010, 02:43 AM
  2. need post processor for mazak 640m nexus controller
    By Rcky123 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2007, 08:23 PM
  3. Mazak Mill Circular Interpolation problem
    By DublJ in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2007, 06:13 PM
  4. Milling 37 degree chamfer around a circular piece...
    By peter.blais in forum MetalWork Discussion
    Last Post: 09-20-2006, 06:47 PM
  5. Circular Milling - G12/G13
    By HPT in forum Servo Motors / Drives
    Last Post: 05-14-2006, 07:22 PM
