585,660 active members*
3,199 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Looking for drives like copley 423 any opinions?
Results 1 to 6 of 6
    Mar 2005
    271
    I'm looking to purchase some drives for a anilam crusader m control retrofit. The servos are Sem 142vdc and 30amps.I plan on installing encoders also. If anyone has any opinions I would really appreciate it.
    Thanks Mike
    15362
    Re: Looking for drives like copley 423 any opinions?
    Quote Originally Posted by CATCH22 View Post
    Thanks Mike
    If you are doing a complete retro fit, then you would be better off with something like Dmm
    They are in BC
    DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Mactec54
    24220
    I have used both Copley and the A-M-C drives and they are very nice drives, but keep in mind these are ±10vdc analogue control.
    Although somewhat superior to step/dir they do not interface if using Mach etc.
    If you do end up using them, use them in the torque mode, not voltage mode.
    Al.
    Albert E.
    Mar 2005
    271
    Al.
    OK thanks AL.
    Mar 2005
    271
    They are in BC
    Have you used there stuff or know someone that has, looks like a pretty good deal for the 3 axis kit.
    15362
    Yes I have, and many other on the zone as well, there main market though is direct OEM sales
    Mactec54
  1. Precix 9100 -Copley Controls 800-700 Servo Motor amplifier went bad
    By wdysf150 in forum Servo Motors / Drives
    Last Post: 12-18-2013, 01:59 PM
  2. Info Needed: Copley 306AP and Moog 152F427A drives
    By p27182 in forum Servo Motors / Drives
    Last Post: 01-24-2013, 05:19 AM
  3. Anyone know the pinout for a Copley Controls 526R?
    By digits in forum Servo Motors / Drives
    Last Post: 03-21-2009, 12:21 AM
  4. Belt Drives, advice,opinions,experiences.
    By OzDragonflyer in forum DIY CNC Router Table Machines
    Last Post: 12-24-2008, 05:17 PM
  5. Copley Model 215 specs
    By macona in forum Servo Motors / Drives
    Last Post: 07-04-2007, 05:23 PM
