586,000 active members*
4,836 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Advice on control change for XHC based large CNC router
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    35538
    Re: Advice on control change for XHC based large CNC router
    Looks good.
  2. #22
    Nov 2013
    152
    I’m calling this conversion done for now. When CNC12 v4.12 comes out I’ll get the gantry squaring working. The parts arrived for my chip (plastic and aluminum) blower arrived, so I’ll add that soon and wire the solenoid valve to an output via an interposing relay. My thought process is if the solenoid inductive kick takes out a relay, if rather it be an external relay. I wish I had the drive fault outputs working.. not sure what the deal is there. The Centroid control is a dream compared to Mach3 on the unreliable import motion comptroller.
    I reinstalled some of the original wire gutter to clean things up a little. I picked up a new labeler that will print the shrink sleeve labels. It works great.
    Control cabinet after:
    Operator station:
  3. #23
    Nov 2013
    152
    I’ve planned on sorting out a touch probe on the cnc router since I installed the Centroid Acorn control. It has a probe detect feature that locks out the spindle when the probe is in use to prevent damage to the probe. Because it’s going on the router when I found out about a wireless option I knew that’s what I wanted. I bought Cliff Hall’s really well made ITTP (impact tolerant touch probe) and XoomSpeed’s wireless conversion. Both items are truly impressive.
    I drew up a terminal box to mount my probe detect manual pushbutton next to the spindle and printed it on the 3d printer.
    Today I got it all wired up and working. There’s an additional probe receptacle on the box in case I ever want to use a wired probe.
    First order of business was getting concentricity dialed in. I got it to a few tenths. As good as it got today.
    https://youtu.be/RCbBTLvJmEg
    Then run a bore probing cycle on a known bore size and see how things look. I am really happy with the probe and the wireless conversion. I'm excited to add this to the control. Lots to learn!
    https://youtu.be/Vq0vpjdb4bM
Page 2 of 2 12
  1. Looking for Advice on Purchasing a Taig based CNC
    By GoofOff in forum Taig Mills / Lathes
    Last Post: 08-15-2018, 05:14 AM
  2. advice for new KFlop-based router?
    By justin.good in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-28-2013, 06:21 PM
  3. Some advice needed with DIY driver based on TB6560AHQ
    By mr.eemay in forum Stepper Motors / Drives
    Last Post: 08-31-2010, 07:20 PM
  4. Midwest based young machinist looking for some advice
    By Myrmidon in forum Mentors & Apprentice Locator
    Last Post: 05-12-2010, 08:58 PM
  5. Large (4'X10') build based on Chinese CO2 tube
    By R and G Leather in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-07-2009, 01:15 AM
