585,977 active members*
4,180 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Problem: Mach3 Mill and Breakboard Card NVUM SK USB 100K Hz 4 axis
    Feb 2013
    33
    Thumbs up Problem: Mach3 Mill and Breakboard Card NVUM SK USB 100K Hz 4 axis
    I have bought and Breakboard USB
    Novusun CNC
    MACH3 USB Card NVUM_SK / 100K / 100kHz
    I'm talkins about this Attachment 391094
    If I know about the issue, I would have not bought this card!
    This card comes with a CD with Mach3 and a Special "DLL" to install as a "Plugin" to do Mach3 working with USB Cable! But it creates a lot of bugs!
    #1: After you configure SoftLimits and the "Slow Zone", the SLOW ZONE does not works... the Mach3 immediately atops when any axis reach the limits. The machine stops very rough, maybe loose some steps, I don't know.
    #2: While Mach3 is running, the screen does not show how many "mm/min" or "inch/min" the software is working... (the real pulses per rev).
    #3: I tried to use a Index Sensor to control my spindle rpm with a feedbac but it does not work!
    The Mach3 recognizes my index sensor, at "diagnostics screen" I can se the Red Light turn on and turn off... but after the Plugin of this card loads, it stops working! I still made a test trind to create the "index sensor" using the option: "Emulate" and the Mach3 does not recognizes it.
    I have made a video in Portuguese about this, I think you can understand easily what I was tryind to do.
    https://www.youtube.com/watch?v=6fpZVrosYac
    Anybody with same problem? Any solution?
    Re: Problem: Mach3 Mill and Breakboard Card NVUM SK USB 100K Hz 4 axis
    Most if not all of the Mach3 chinese motion controllers have some issues. Some more than other. The solution is to buy one that's well supported, and not from China. Popular boards are the Smoothstepper, UCxxx series from CNC Drive, and Pokeys.
    Jun 2018
    Issue with Breakboard
    The above query is very much important in order to know the breakboard card NVUM SK USB Hz 4 axis which is going to need specification for the process where you can find the error and try to solve the query and it will take time so for that you can take the help from dell printer support for the information part .
  1. Mach3 - USB motion card communication problem
    By Lama2 in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2024, 12:21 AM
  2. Mach3 PCI Parallel Port Card Problem
    By firlefranz in forum Mach Software (ArtSoft software)
    Last Post: 10-12-2014, 08:35 PM
  3. Looking to buy 1st CNC Mill 90 - 100K
    By RiverDave in forum Want To Buy...Need help!
    Last Post: 12-24-2009, 11:02 AM
