585,973 active members*
4,081 visitors online*
    Jul 2017
    50
    LeBlond Makino FNC-128 PLC information
    Shop I work for has an FNC-128 with Fanuc 6MB control and what Makino was calling an 'UM15A cpu' for handling PLC related stuff.
    Today the 5 volt power supply for the UM15A died and unfortunately I didn't check to see if the wires were labeled before ripping it apart so I have a 50/50 chance of getting the polarity right when the new power supply comes in. It seems like I have an incomplete electrical drawing for the machine, plus there's a whole lot of undocumented stuff that happened in the electrical cabinet over the years.
    I tried looking for anything from Fuji who has their name on the circuit boards for this PLC and can't find anything.
    Anyway the 5 volt wires go to the backplane on two wide traces that wrap around the outside in a C shape
    Attached is a picture of the lower portion of the backplane. The two wider traces you see on the bottom. I could assume the outside trace is the (-) bus, but I'd like to try to make absolute certain of this.
    So, does anyone know the polarity, or would anyone know where I could find out a little more about this PLC?
    Jul 2017
    50
    Re: LeBlond Makino FNC-128 PLC information
    For future reference. The negative bus on the backplane is the outer trace.
    Hooked up my new 5VDC power supply and she works.
  1. Leblond Makino T\C Problem
    By falcon64 in forum DNC Problems and Solutions
    Last Post: 10-22-2014, 12:12 AM
  2. Leblond Makino RMC-55 3Axis
    By Masood in forum CNC Machining Centers
    Last Post: 05-08-2012, 02:58 AM
  3. Leblond Makino EH 6
    By southprecision in forum EDM Discussion General Topics
    Last Post: 02-26-2011, 02:13 AM
  4. Leblond Makino FNC60 ????
    By SGARCIAM in forum CNC Machining Centers
    Last Post: 03-14-2008, 03:25 AM
  5. LeBlond Makino
    By jhhdez in forum CNC Tooling
    Last Post: 01-17-2008, 10:34 PM
