Hello cnczone members!
I have an issue with my laser cnc 50 w chinese cutter.
I don't have clear cut. The cutting line is not smooth. I attached a photo with the problem. Has another member this issue?
Thank you!!
Thank you!!
hi
looks like your pattern has been created in to lower resolution
i hv no idea this problem.......................
The programof laser is RDWorks. I use Corel draw to make the pattern and i import the dynamic drawing to RDWorks. How can i see if the drawing is in low resolution?
Thanks a lot!
Draw a circle in the laser software and test. This will take the image out of the equation.
try less power and 2 passes
