585,719 active members*
4,506 visitors online*
IndustryArena Forum > CAM Software > CamWorks > G41 BOMBS every time in post process Haas VF3 CAMWorks
    Sep 2007
    122
    I have a simple profile and no matter what I choose on CAMWorks for Solidworks 2018 , the post processor will not get it correct. I am running this on a Haas VF3 and this actually calculates I and J incorrectly every time. Below is the post. I did find a reference to the lead in value but nothing seems to work there either. I have a 0.498" Endmill and it has the correct diameter offset in the machine. The roughing post works but there is no G41 in that one. I get Tool Compensation errors every time.
    O03106(LEAD IN AMOUNT)
    G20 G17 G40 G80 G90
    T06 M06 (1/2 EM CRB 4FL 1 LOC)
    G54 G90 G94
    S3000 M03
    G00 G90 X-.4631 Y.2204
    G43 H06 Z1.1 M08
    G01 Z.75 F35.
    G90 G41 X-.2793 Y.4043 D06
    G03 X-.25 Y.475 I-.0707 J.0707 (dead here)
    G01 Y1.75
    X.5
    G02 X1.35 Y.9 I0 J-.85
    G01 Y.6663
    Sep 2007
    122
    Re: G41 BOMBS every time in post process Haas VF3 CAMWorks
    It looks like if I use near zero "D" offsets this will run. This post processor looks like it sucks.... Is there a way to have it use actual tool diameters in the machine or only zero with a bit of wear?
    Sep 2007
    122
    Attachment 391350 I had to add compensation to the lead in lead out and tweak the settings on the profile. There must be a default setting to make sure this is always on. I'll check.
  1. Need Haas vf1 post process
    By chitpon in forum Uncategorised CAM Discussion
    Last Post: 10-11-2017, 10:29 AM
  2. Need Haas vf1 post process
    Last Post: 09-29-2014, 06:59 AM
  3. Camworks Post for Haas SL20
    By rrbmachining in forum Haas Lathes
    Last Post: 09-10-2010, 09:34 PM
