585,930 active members*
3,715 visitors online*
    Mar 2018
    54
    Angry windows 7 and makercam issue
    I have just finished building my cnc and it seems to work great. Except for some G-code that I generate from makercam. Whenever I build G-code in Makercam the code is there on the screen and in the viewer you can see hundreds of circles around the text g-code I just made. If I run the file it makes all those circles? I am sure it is Windows 7 but maybe there is some kind of workaround... It only happens on the windows 7 PC that runs the cnc machine. In my office I use a laptop and I have a copy of Mach3 on bothbut I cant run the cnc with the laptop. On the laptop there seems to be no visual problem and in the G-code there is nothing more than the Text G-code that was made in Makercam (no circles ) . So it shows up fine on the Windows 10 laptop and corrupt on Windows 7. If I run G-code that came from the Mach3 download it works fine. I don't know if there is any other source that might give me a problem because I have not tried anything else yet but if someone knows about this please let me know.
    Jan 2016
    386
    Re: windows 7 and makercam issue
    See this post. Might be the same issue.
    https://www.cnczone.com/forums/taig-...creenshot.html
  1. MACH3- windows xbox wireless - windows 10 64bit plugins not working
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-02-2018, 04:48 AM
  2. Replies: 3
    Last Post: 06-14-2017, 08:45 PM
  3. Windows 10, any issue with SprutCAM
    By LRF in forum Torchmate
    Last Post: 07-27-2016, 03:29 AM
  4. Display issue with Windows 10 and V6
    By moldcore in forum Surfcam
    Last Post: 09-14-2015, 04:08 PM
  5. Haas Control/Windows 7 Issue's
    By dengo in forum Haas Mills
    Last Post: 11-01-2012, 06:52 PM
