Hello all,
I'm looping a program with Macro to machine a bunch of OD splines on a HAAS SL-40 using the C-Axis using "While/DO/END". I'm using "H" incremental rotations.
Problem: Macro Variable is being correctly calculated to the 22.5 degrees I need to rotate, however the machine itself is actually rotating 225.0 degrees!
If I change the Variable to 2.25 degrees, the machine rotates 22.5 degrees.
This leads me to believe this is a setting/parameter issue that put incremental rotation out one decimal point? Does anybody have any light to shed on this?
