585,942 active members*
3,339 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > No go on cycle start
Results 1 to 7 of 7
    Apr 2018
    Angry No go on cycle start
    Hi, All
    I have a 96 BMC 4020 SSM I'm at a lose. It will not start a cycle the button blinks green but no go. I have control power and I can manually move all axes. turn on the flood and wash down but will not start a calibration cycle. On start up i had a CMOS error battery so I replaced it and this error is fixed now. I also check the power supply and the 24V power supply there with in spec. I have replaced the all relays on the I/R board too. I pined out all the cable between the control pendent and the cabinet so far no broken wires. I check the buttons ( power and cycle start) i have continuity thru both and switch them and both are seem to be good. I remover the PC hard drive an slaved it to one of the office computers i scanned it for viruses and defrag it and it checked out ok. The hard drive is only 3 years old. I reinstalled and fried up the mill and still have the same problem. Right before it quit work completely I was running a cycle and had some light chatter or vibration in milling. It shut down the control power which is not the first by any means. it will generate a I/R fault error. this has happened a lot in the past. So I have had too reset the servos 10 to 15 before the control power would return. Of course in the middle of a machining cycle. Most of the time I have to shut the main power down and restart the machine.
    Any ides I'm open
    I have also had these error once or twice before
    1.) Servo Fault - I/R Fault a lot
    2.) Spindle speed fault sense - not at commanded speed ATC error on selecter operation spindle fault - Orient error one time a year ago
    2.) Could not access dual port ram on Matrix 4-XYZS Servo board 2 or 3 time a year or so ago
    Jun 2008
    1104
    Re: No go on cycle start
    There is a little solid state relay on the board in the console. It may have failed.
    Jun 2010
    104
    Quote Originally Posted by bloke View Post
    Bloke,
    I know this is super old. I have 98 BMC4020. Getting Server Fault - I/R Fault as soon as I press the Cycle Start.
    You mentioned a relay on the control board? Can you elaborate on which board?
    Thanks in advance,
    Henry
    Jun 2008
    1104
    The little relay is on the PCB in the console (not the main Console node but the PCB mounted directly to the back of the membrane keyboard). This is only in the SSM consoles not the MAX 3 consoles. If you have two screens, this isn’t you.
    Open the back cabinet doors and see what LEDs light up on the I/R module. This is the unit to the left of the spindle drive. It sounds like you have a fault with this.
    Jun 2010
    104
    Thanks Bloke,
    So, I turn the machine on, I/R Module light is green until Ultimax 3 boots up. Then the green light goes out. The Yellow light "should" illuminate but it doesn't appear to.
    I check the voltage on pins 63 and 64 and the do have 24v. On them. The moment I press cycle start, I get the fault and the green light comes back on, on the I/R Module.
    I've watched what happens and and on the Hurco Control Relay Board I noticed (and hear) relays click and CR6 has a green light illuminated while non others are. Not sure if that's related.
    I've been starring at the Siemens Engineering document and it seems that few tests it outlines (checking voltage on various pins I/R module) seem to pass.
    Here are a few images that may give a clue.
    Thanks again for any help,
    Henry
    Jun 2008
    1104
    Apr 2024
    6
    Bloke of your still out there please help.
    i got a keyboard hooked up managed to press f1 and got into the Cmos settings i followed a hurco service bulletin and went through all the standard and advanced settings.
    I copied what bloke suggested in another post for the cylinder heads 1223 sect 50 etc amd manged to boot the system.
    It brings me to the part set up screen and the progam screen
    But the main controller none of the buttons work i can only use the keyboard.
    It wont allow me to press manual power, cycle start to enable the drivers.
    Its like the machine has forgot ot has the controller all the parameters needed to set it up arent there.
    Really need help here if anyone even reads these anymore
  1. cycle start
    By toyshop in forum Tormach PathPilot™
    Last Post: 12-14-2016, 04:17 AM
  2. Cycle start inhibited
    By irfacnc in forum CNC Machining Centers
    Last Post: 06-26-2016, 07:08 AM
  3. g-code cycle not start
    By pisagor in forum Mach Mill
    Last Post: 11-20-2012, 03:52 AM
  4. Remote cycle start
    By REVCAM_Bob in forum Fanuc
    Last Post: 03-19-2007, 01:08 AM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
