585,764 active members*
4,233 visitors online*
    Apr 2018
    6
    Exclamation RichAuto A11(S) - DSP fails to initiate
    Hi. This is my first post on this site, so please excuse me if I'm not posting in the right place.
    I have a Chinese machine (OMNI-CNC Jinan 1325) with RichAuto A11 DSP controller and a MACH3 controller (I've never run it from the Mach3 controller... wonder if that is part of the problem?!)
    Everything has been running fine... until I switched off the power (mains) for about 3 weeks and when I came back, the machine powered up ok and the DSP lights up, but no menus... nothing.
    I've tried unplugging DSP from controller, holding down the OK button for extended time (as suggested in another post on here). I can't seem to get it going ~at a loss for what to do.
    Can anyone help out??
    Thanks in advance!
    Sep 2017
    Quote Originally Posted by CBurr View Post
    Thanks in advance!
    Hi CBurr
    I have the same problem, Did you manage to solve it?
    I found in an Egyptian forum that the problem is in the eeprom and you have to flash it.
    But I couldn't find the .bin file.
    Jun 2018
    362
    Re: RichAuto A11(S) - DSP fails to initiate
    Leave the CNC machine switched off (or disconnect from CNC machine cable to prevent any external influence) and connect the USB cable to PC. It should power up normally. If that works then there may be no power being supplied via the 50 pin cable. Check down the control box end.
  1. RichAuto vs Mach3
    By dixdance in forum Controller & Computer Solutions
    Last Post: 01-02-2024, 10:56 PM
  2. Anyone using RichAuto A51 dsp
    By RobSm in forum Chinese Machines
    Last Post: 08-08-2017, 08:59 AM
  3. RichAuto A11
    By oklop in forum Controller & Computer Solutions
    Last Post: 04-11-2017, 09:39 AM
  4. can I initiate a drip feed dnc with a macro from the controller?
    By heavy metal in forum Mori Seiki lathes
    Last Post: 07-05-2012, 01:55 PM
  5. 6T B will not initiate a program
    By steffeydn in forum Fanuc
    Last Post: 12-13-2010, 08:25 PM
