585,992 active members*
5,238 visitors online*
    Apr 2018
    Question Pressure Sewage line (camp 1000-5000PE)
    Hello, colleagues!
    I need your help with the design of pressure sewage pipeline for Camp in Africa (scheme is attached);
    I am going to install 4 WWTP 200m3/day each.
    I plan to use PVC pipe and a lot of Lift Stations.
    Have no experience with pressure line so big scale.
    Next issues I got:
    1) Which materials are better to use and which type of connections?
    2) Is it accurate Lift Stations locations on the Layout?
    3) Any comments are highly appreciated!
    Link for Layout in good quality:
    https://www.dropbox.com/sh/7qjkd7hv4...K8hZnR_da?dl=0
    Apr 2018
    Re: Pressure Sewage line (camp 1000-5000PE)
    To make our discussion more clear I attache simplified scheme here with 4 buildings and 3 lift station. I know that 280 persons and 5 lift station are feasible. But does it make sense if you have 1000 persons, 5000 persons and 10 lift stations or 50 lift stations? Can pump of the lust lift station handle with effluent?
    Dec 2005
    594
    You're probably better off asking your questions on a civil engineering forum. What you're asking is pretty much out of scope on this forum. This sub forum deals primarily with mechanical engineering.
    Apr 2018
    19
    Eng-tips.com has experts and resources along these lines.
  1. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  2. Air Line pressure
    By Skiroy in forum Mechanical Calculations/Engineering Design
    Last Post: 08-07-2012, 01:44 AM
  3. Replies: 2
    Last Post: 07-19-2012, 02:36 PM
  4. Bridgeport VMC 1000 oil pressure
    By racerdog in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2009, 09:31 AM
  5. DIY coolant system with loc-line - how much pressure?
    By Eddiep in forum Benchtop Machines
    Last Post: 09-07-2007, 09:13 PM
