585,994 active members*
4,692 visitors online*
    Oct 2013
    30
    XZero 30x60 Raptor Settings
    After far too long my 30x60 Raptor is finally up and moving. I`m hoping there are some XZero owners running a similar setup that can help me get the best performance out of my machine.
    Setup is as follows:
    382 oz-in Nema 23 steppers (HS23B30A) - 5 A/phase 1.9 mH (8 wire stepper wired in parallel)
    Leadshine MX4660
    Meanwell 48V 10A power supply (NDR-48-480)
    2010 ballscrew on X-axis
    1605 ballscrew on Y-axis
    1605 ballscrew on Z-axis
    Controlled via UCCCNC using a UC300ETH-5LPT
    MX4600 settings:
    Current DIP switches set to 4.95A peak to match steppers?
    Recommended micro step resolution settings?
    Engage 'smoother' switch?
    UCCNC:
    Recommended velocity and acceleration settings?
    I would very much like to change my Y-axis to a 1610 ballscrew to keep the stepper motor RPM down. The machine was supposed to come with a 1610 but was supplied with a 1605 and I was never able to get it resolved with George before he went offline. I'm told the end machining on the ballscrew isn't generic so I have been reluctant in sourcing an EBay vendor that can machine a 1610 screw to George's dimensions.
    Any and all info is appreciated.
    Apr 2015
    Re: XZero 30x60 Raptor Settings
    I have nearly the exact same setup but I'm also just finally getting it put back together.
  1. Spindle motor and VFD for Xzero Raptor?
    By Jfclouti in forum Want To Buy...Need help!
    Last Post: 09-09-2016, 02:37 AM
  2. Xzero Raptor 30 Vs. CRP2448 (CNCRouterParts) Which to buy??
    By grizak in forum Want To Buy...Need help!
    Last Post: 01-27-2016, 06:03 PM
  3. 30x60 Xzero Raptor
    By Donny M. Carter in forum For Sale Only
    Last Post: 09-22-2015, 07:53 PM
