Hi there
What I want to ask is about Spindle Drive, which is:
KDA 3.2 series.
when I connect the " Control Voltage Bus ( X1 pin assignment 16way bus ), unfortunately, the power unit stop output voltage( eliminate POK ) and nothing mirrors in the spindle drive.
also, I remove the 24-volt wire from Power control board( Inside of the spindle drive unit, Which I attached the picture in post) POK goes OK green and spindle drives Fault ( red LED) turns ON.
Does anybody have the same experience?
any help will be appreciated kindly.
With Regards
Russell
