585,877 active members*
3,601 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > XYZ Gantry Routers > Heavy Chinese spindle on lightweight machine. Counterweight an option?
    Dec 2008
    7
    The machine is a Zenbot 1216 but I guess the question applies to all lightweight gantry machines.
    The Zenbot is currently fitted with a Dremel but I have an unused 800w wc Chinese spindle that seems to me to be too heavy to use on such a small machine.
    I'm thinking of fitting a pulley on a shelf high above and having a counterweight take the load off the Z axis. Would this work or are there problems with doing this?
    Apr 2004
    5737
    Re: Heavy Chinese spindle on lightweight machine. Counterweight an option?
    You could do that, but it would also put a strain on the gantry as it tried to move around. It might be better to use a gas spring, like the struts that hold a hatchback open.
    Andrew Werby
    Website
  1. New machine - G540 - 110V Huanyang VFD - Chinese spindle 1.5kW
    By dubdzine in forum DIY CNC Router Table Machines
    Last Post: 01-24-2024, 05:20 AM
  2. What does a high end cnc machine have for a counterweight?
    By slashmaster in forum Benchtop Machines
    Last Post: 04-22-2017, 01:45 PM
  3. Need CNC Machine for lightweight Chassis
    By rjar in forum Want To Buy...Need help!
    Last Post: 05-24-2011, 05:04 PM
  4. Which Chinese laser option to go for ?
    By evans in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2011, 01:36 PM
  5. lightweight spindle for engraving?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 03-14-2007, 04:48 AM
