585,748 active members*
3,508 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > How do you Emboss letters in Aluminium signs.
Results 1 to 9 of 9
    Jan 2007
    9
    I recently purchsed an embossed Aluminium sign; the letters and the surrounding boarder are raised. The bottom part of the letters has got quiet a radius on it so I do not think it is pressed with a top and bottom former.
    Any ideas as to what is involved would be greatly appriciated.
    Jul 2005
    12177
    Quote Originally Posted by stone1925 View Post
    I think soft material like aluminum is sometimes embossed with just one die having the letters and the other being polyurethane. It is possible to get polyurethane with all types of flexibility and it can be deformed a lot of times without deteriorating.
    Jan 2007
    9
    That might account for the radius on the base of the letters. Do you think that they use some sort of press and what material might the letter formers be ?
    Jul 2005
    12177
    Some sort of press. Probably on a commercial machine the letters are hardened steel. I have used just cold rolled steel for make recesses in aluminum plate up to 1/8" and cold rolled lasts a very long time. You just can't have any really fine detail or keep the corners completely sharp.
    Oct 2007
    have you looked here... www.creationdisplay.com
    Aug 2007
    71
    Quote Originally Posted by Geof View Post
    Can the die be the negative? As in, if the letters were plasma cut out of a sheet of steel? I take it this would require significantly more pressure from the press?
    May 2005
    64
    Embossing
    So many questions...
    I made an embossing tool out of a piece of 1" thick 6061t6 alum. I used a piece of fairly stiff urethane that was about .125" thick, pushed with a block of steel 1" thick. The aluminum was sheet, maybe .025" thick.
    The art was no deeper than .08"
    So many variables,
    what material and how thick?
    Alum presses easier than steel
    How deep an impression is needed?
    How fine is the detail?
    My suggestion: do like I did. Try something and learn from it.
    Feb 2007
    33
    FOR EMBOSSING, I USE MY ENGLISH WHEEL WITH A FLAT DIE. I MAKE THE PATTERN OR LETTERS AND USE MY FLAT DIE ON MY ENGLISH WHEEL. IT ALSO DEPENDS ON WHAT MATERIAL YOU WANT TO EMBOSS AS WELL. THIS WORKS GREAT ON ALUMINUM OR ANY SOFT MATERIAL. TRY IT YOU WILL BE VERY SURPRISED OF THE RESULTS. HOPE THIS HELPS FOR A DIFFERENT IDEA TO TRY.
    Dec 2007
    I use 50-90d urethane,and rubber.
    I use different materials to emboss.
    I made a license plate mold with trim edge out of brass, and 6061 aluminum. I can interchange art work, and make special plates for companies. I use a 1/4" 90d urethane on the top plate and hit with limits on my 50 ton iron worker. I have seen guys use the e-wheel, pullmax machines,and h presses.
    Should be pretty easy.
    Bill Heineken
  1. create and mill embossed letters
    By CharlesM479 in forum Solidworks
    Last Post: 04-09-2007, 03:17 PM
  2. making wood signs
    By nydheart in forum DIY CNC Router Table Machines
    Last Post: 03-31-2007, 09:15 PM
  3. Hand embossed metal plates
    By ehsankiani in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2007, 08:47 PM
  4. Top Ten Signs
    By wms in forum Community Club House
    Last Post: 06-22-2003, 01:04 AM
