585,974 active members*
4,219 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Recommendations for milling bakelite
    Apr 2018
    Hi guys,
    newbie here with some questions regarding milling parts out of bakelite - we have parts with relatively simple geometry we have to mill out of 10mm and 15mm thick bakelite and need to get end mills for that.
    Apologies if that question was asked before, I was searching the forum but found little on that question.
    For those that have worked with the material before, what type of end mills would you recommend? What RPM and feed rate?
    From what I found on the forum, the hardness of phenolic material seems to dull the bits relatively fast - any experiences on that with bakelite / paper-based phenolic materials (no glass fibre, as I understand it) ?
    Andy
    Apr 2021
    6
    Re: Recommendations for milling bakelite
    Hi, it's been 4 years since you post this thread, did you find the best condition for this?
  1. Turning bakelite
    By Futterama in forum Composites, Exotic Metals etc
    Last Post: 01-29-2014, 11:28 AM
  2. AutoCAD 2D Milling CAM Recommendations
    By BradS. in forum BobCad-Cam
    Last Post: 02-24-2012, 03:56 AM
  3. AutoCAD 2D Milling CAM Recommendations
    By BradS. in forum Uncategorised CAM Discussion
    Last Post: 02-22-2012, 02:01 PM
  4. Milling Brass 360, recommendations?
    By skyline in forum MetalWork Discussion
    Last Post: 06-09-2008, 09:58 PM
  5. Need recommendations for milling titanium
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 09-21-2006, 11:15 AM
