585,948 active members*
3,710 visitors online*
    Mar 2018
    13
    Exclamation Serial Ports only???
    Am I confused? Misinformed?
    Reading old threads?
    Are serial ports the only interface PC to CNC Controller?
    Seems Like rather old technology.
    24221
    Re: Serial Ports only???
    There are also USB interfaced controllers, although these are serial.
    There are motion cards which sit in a PC slot which handle the operation of the CNC functions with PID control directly back to the card.
    Systems such as Kmotion etc use the PC mainly as a HMI and communicate with the PC via a USB port and handle the trajectory planning and servo control on an out board system.
    Al..
    Albert E.
    Mar 2018
    13
    There are also USB interfaced controllers, although these are serial...
    I guess I was just finding a lot of old posts.
    I checked the info on the China Special I ordered, it mentions USB port. So I guess I'm OK.
    Very Noob, here. Still bouncing around from topic to topic, because I know nothing.
    Thanks!
    May 2016
    526
    It depends on the controller but if youve got USB sounds like youll be fine
    Quote Originally Posted by ShellbackBill View Post
    Thanks!
  1. Need Advice On Additional Serial Ports and Switch boxes
    By funktech in forum USB, RS232, PARALLEL etc
    Last Post: 03-21-2018, 08:41 PM
  2. Serial ports and Vista
    By cousinitt in forum Computers / Desktops / Networking
    Last Post: 01-23-2011, 10:26 PM
  3. Two serial ports - what is difference?
    By xiondavis in forum Haas Mills
    Last Post: 10-23-2008, 02:27 AM
  4. Serial Ports over Ethernet
    By cely in forum Computers / Desktops / Networking
    Last Post: 12-24-2003, 07:19 PM
