585,735 active members*
4,821 visitors online*
Results 1 to 7 of 7
    May 2017
    4
    cincinnati cl707
    we bought the cl707 new 10 years ago will be upgrading to fibre soon but in the mean time having a terrible problem with the tip clogging every couple of sheets, as a result were losing our cuts or spending a god awful time on deburring. if any one has had this problem and figured it out please help
    Apr 2017
    28
    Re: cincinnati cl707
    What material are you cutting? MS? SS? what thickness? Your tip may be clogging because your standoff is drifting down to the table. If that is the case, you may have an issue with the lower cone assembly being dirty. CI can help you with cleaning it. I'd guess the tip is hot too (blueish)?
    May 2017
    4
    the tip isn't really getting that hot to the touch by the time we take it off its just dirty and clogged were cutting SS, 24 ga to 12ga. its not really changing color
    May 2017
    4
    Quote Originally Posted by ziggy111 View Post
    nope that wasn't it were in the process of taking the head apart and cleaning it , the lower cone assembly wasn't that bad
    Apr 2017
    28
    is the cut orangish or blue? If it looks like it is a bit orange than you probably have O2 leaking past the shuttle valve (one way valve) and mixing in with the N2. Test by shutting off you O2 assist gas bottle, purge out the gas line by selecting N2 for about 5 min. then cut, if the cut is back to good replace the shuttle valves attached to the piping in the z plate (to the left of the head), should just replace the assist gas solenoids too while your at it.
    May 2017
    4
    we run straight nitrogen ,we have our own little nitrogen plant set up just for the laser.
    Apr 2017
    28
    what is the condition of the lens drawer seals, they can be worn and leaking the N2. you can check by removing the head cover. placing your finger over the tip and then turn on the n2, may want to overide the gas down in psi maybe to 50. Then while fingure is covering tip and n2 is on place other hand in front of the lens drawer and if you feel a breeze(wet your fingers), replace lens seal (white ones at the bottom of the lens holder)
  1. Cincinnati
    By diazosvaldo in forum Spanish
    Last Post: 01-30-2010, 12:33 AM
  2. Cincinnati CL-707
    By Benjamin P. in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-20-2009, 10:34 PM
  3. DNC on Cincinnati FV 750
    By DHYSTA in forum Fanuc
    Last Post: 02-27-2008, 01:30 PM
  4. Cincinnati FTV
    By yorel23 in forum Uncategorised MetalWorking Machines
    Last Post: 04-09-2007, 09:24 AM
