As most know, I've been setting up a VH-5C and I followed the manual and used SetP to set the M60 Brake to ON.
From reading the manual, I understood that when this is set, the Brake will automatically apply after an A axis move, and turn of before a move.
Is this correct?
If so, how do I test it? I can do a M60 in MDI and the brake applies, then a M61 turns it off. Great.
But, if I do a G0 A180.0 the Rotab turns to 180 degrees but I never hear the brake engage.
Is there something else that tells it to turn on, or should I ignore Auto mode and insert a M60 and M61 in my G-Code everywhere?
Thanks,
Richard
