Greetings.
My first post, but not new to this forum or to CNC. In the past I've converted a lathe to CNC and built a small CNC milling machine. Both running Mach3 with parallel port cards. For a recent project (laser cutter) I got an inexpensive USB card from China. It appears as BSMCE04U or STB4100, probably other designation, but all seem the same (photo and suggested wiring diagram attached).
The cards works well (under windows 7) except the shearing of limit and home switches. In past project I have used the same switches as home and limits, but when I try to do it in this card it trips a limit imminently when first axis reaches home.
I think this was discussed here before, but I am wondering if anybody found a solution or a scrip that will disable the limits while homing. I've tried to do a Brain script, but I am not too good at this.
Thanks!
Bill
