585,991 active members*
4,725 visitors online*
Results 1 to 6 of 6
    Apr 2018
    4
    G0704 Spindle Upgrade
    Hey guys i am new to the forum. I am building a cnc g0704. It will have the bearing upgrade, belt conversion, and power drawbar. I am wondering if the motor posted below would be a good choice with 36-60 pulleys so it will have a top spindle speed of 5k rpm. I am wanting a servo motor so I can do power tapping. Any experience you guys may have with servo motors for the spindle would be greatly appreciated.
    https://www.fasttobuy.com/18kw-220v-high-speed-servo-motor-3000rpm-nema-42-6nm-ac-servo-motor-drive-kits-for-cnc-router_p35894.html?gclid=Cj0KCQjw2pXXBRD5ARIsAIYoE beMigPoLGrPJSSKKijvYnqqllikFJ5bbGgVokO7YtlldQmdFrv ZynQaAqYMEALw_wcB
    Re: G0704 Spindle Upgrade
    That doesn't look like a terrible package. You are going to hurt your torque pretty badly with that overdrive and that will certainly change your feeds and speeds.
    Personally I'd go with a BLDC and driver that's capable fo 6k from the factory. 2.2kw is a good range, just make sure it works on 220v, lots of them are 320v especially from Asian vendors.
    Apr 2018
    4
    I ended up going a different route and bought a kollmorgen akm42 servo motor. It has about 2hp, 6k rpm, and roughly twice the torque of the other motor. I got a great deal on ebay for a brand new one.
    Cool! What kind of hardware and software you using to control it?
    Apr 2018
    4
    Kollmorgen driver of some sort off of ebay to a normal breakout borad. Using mach3 or 4. havent decided on which one yet. x,y,z axis' will be run with clearpath servo motors.
    Sep 2020
    I know this is a old thread but did you ever get the servo installed and were you getting 6000rpm? Also can I get the driver model number?
  1. G0704 2 HP 3 phase spindle motor upgrade
    By CodeRage in forum Benchtop Machines
    Last Post: 07-24-2020, 10:26 PM
  2. Replies: 35
    Last Post: 03-21-2017, 02:29 PM
  3. G0704 motor upgrade need help
    By aaronky in forum Benchtop Machines
    Last Post: 06-02-2015, 07:03 AM
  4. Amazing spindle motor upgrade package
    By jcposada in forum For Sale Only
    Last Post: 02-13-2015, 07:03 AM
  5. G0704 spindle upgrade
    By fragger6662000 in forum Benchtop Machines
    Last Post: 04-23-2011, 09:33 AM
