585,971 active members*
4,355 visitors online*
    Apr 2018
    centrum 2000 punch press problem
    Greetings all,
    I am having problem with Murata centrum 2000 punch and the problem is that the press turns off by itself and even the command is on, it will stay for a while than turns on and repeats this all the time which does not allow you to wok.
    The problem first appeared when we changed the hydraulic oil the last time , it may have poblem with pressure but no alarm is shown on display .
    If anyone could help
    Nov 2021
    7
    Re: centrum 2000 punch press problem
    1. If the machine is shut down, the power supply is suspect. ( fanuc side )
    2. dc 24 power supply is suspect ( machine side )
  1. Replies: 7
    Last Post: 11-20-2019, 10:45 PM
  2. Replies: 4
    Last Post: 08-26-2018, 05:09 AM
  3. Replies: 2
    Last Post: 08-10-2018, 03:46 AM
  4. Can't get Centrum 2000 into jog mode
    By metalguy2000 in forum Fanuc
    Last Post: 02-21-2017, 06:49 PM
  5. 1994 Centrum 2000 with Fanuc 0-PB
    Last Post: 02-20-2017, 09:48 PM
