HAILEA ACO-009E 110v AIP PUMP/AIR COMPRESSOR FOR LASER MACHINE
1 The case is made of high quality ZL 102 aluminum alloy with streamline design heat-dissipation is more effective.
2 Driven by electrical magnetic motor, adopt straight-line reciprocal motion to produce air more reasonable in structure.
3 Adopt SF3 new type wearable material for the cylinder and piston, which is of lower power consumption, large air output and high air pressure.
4 Non-oil lubrication design, the compressed air is purified.
Voltage: 110V
Frequency: 60 Hz
Power: 160W
https://www.ebay.com/itm/263612461796
Peak Sign inc
www.peakofglass.com
www.peasign.ca
485 Finchdene Square Unit # 1, Scarborough Ontario M1X 1B7, Canada
[email protected], [email protected]
647-620-8689, 647-873-6083
