I have a problem with x axis, I turn on machine operation, x axis goes left to right for about 5 minutes, works properly, and then it suddenly stops, and in mach3 works g.code to the end x axis a few seconds when g.code change the movement from left to right then, the x axis starts moving from where it stood, which is wrong, can anyone help with this anomaly, thank you?
