585,925 active members*
3,489 visitors online*
    Jun 2017
    143
    Connecting Probe Ground
    Can someone tell me if there is any issue with permanently connecting the group wire for the probe permanently to the spindle body (rather than using an alligator clip to connect it to the endmill when needed)? I can't think of any problem since the spindle body should be electrically isolated from everything else.
    Simon
    Mar 2017
    1310
    Re: Connecting Probe Ground
    You can and you should. Spindle body should be grounded.
    But spindle body and endmill are not electrically connected on all spindles. Specially if tool moves electrical connection through rotating bearings is very week. But if you determine that this is not an issue on your machine then you can do it.
    Nov 2012
    1267
    I mounted a brush contact touching the shaft on the top of the spindle. My spindle is a small 400W BLDC motor:
    Mar 2017
    1310
    This is from one of our test machines.
    Jun 2017
    143
    Thanks guys, I think my spindle has a good connection already, but will check it out with a multimeter while turning the spindle by hand to confirm.
  1. Replies: 9
    Last Post: 07-21-2017, 02:02 AM
  2. Need Help Connecting a Probe to PMC
    By NTLSYS in forum Fanuc
    Last Post: 09-17-2015, 07:44 PM
  3. connecting probe? 0m-a
    By landslide1 in forum Fanuc
    Last Post: 08-02-2014, 10:11 PM
  4. connecting xyz probe to xbox360
    By tiofilo123 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-25-2011, 05:29 AM
  5. Z-axis goes crazy when connecting plasma ground clamp... please help
    By Killerdub in forum Waterjet General Topics
    Last Post: 09-14-2010, 08:07 PM
