585,743 active members*
4,958 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Engraving Painted Aluminum - Best painting recipe to use
Results 1 to 11 of 11
    Dec 2015
    37
    Not sure if this is the correct section of the forums for this question. If not please let me know.
    I am trying to engrave painted aluminum but currently still see some flaking along the cut line. I see this with engraving bits and even small ball nose bits. I run the engravers at 10ipm with anywhere of 0.01 to 0.025 DOC.
    I am currently painting 6061-T6 where I use 150grit to scuff the surface and then clean with acetone. I lay down Rustoleum Self Etching Primer and after 30 minutes of the last coat I use Rustoleum Metallic or Rustoleum Universal brands of paint. I dont even start trying to engrave them for about a week so I know they have had a long enough time to cure.
    So with that I was curious if there is anyone that has any different experiences they are willing to share or see if my prime/paint process needs to be corrected.
    Oct 2015
    24
    Re: Engraving Painted Aluminum - Best painting recipe to use
    I did some engraving a couple month ago, but used a piece of anodized aluminum from ebay, not sure what your best bet will be for paint.
    1/16" Dremel ball mill engraving cutter, .01 depth, 5000 RPM 7 IPM with WD-40 sprayed on surface before starting, keeps the little chips right there beside the cut.
    Sorry, I'm not much help
    Dec 2015
    37
    Quote Originally Posted by MO Metal View Post
    I had thought about using anodized aluminum as well but I cannot get it in the size I need and the colors are very basic and bland. So that left me with getting the aluminum in the sizes I need and do the paint color I like. More time consuming but if I can get the flaking part sorted out it will be worth it..
    Dec 2013
    5717
    You might try etching the surface with phosphoric acid (milkstone remover), available at any farm supply and many other places), hydrochloric acid (muriatic acid) works also. Then prime with zinc chromate primer. Rather than let the paint dry hard, you might try engraving while it is still somewhat soft. That might help with the flaking.
    Jim Dawson
    Sandy, Oregon, USA
    What about powder coating?
    Jun 2010
    4256
    If the paint flakes, it is hard. Try engraving while the paint is still soft.
    Cheers
    Roger
    Dec 2015
    37
    That might be too long of a process and too costly but does it work better than just a self-etch primer?
    Never thought about engraving while it soft could look into that.
    Dec 2015
    37
    if I remember some time ago I looked into and it was more costly. Also I don't know how powder coating holds up when being engraved.
    Dec 2013
    5717
    Quote Originally Posted by nodott View Post
    It wouldn't take any longer than roughing with 150 grit and washing with acetone. Just wipe it on, it reacts almost instantly, and rinse with hot water. Allow to dry and paint. The zinc chromate primer makes a good bond with the aluminum.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2016
    Engraving powder coat works great.
    I engrave fine line text for electronic enclosures. 6061 - t6 from Industrial metals.
    Try better paint like a catalyzed auto paint.
    You will need a compressor and sprayer though.
    Lay it on as thin as possible.
    Dec 2015
    37
    Quote Originally Posted by 65patch View Post
    I have a friend that is looking into getting automotive paint that will match the colors that I need. He has a spray booth and I will just pay him for the work. Other than that I have had some success by starting off first with lesser depth of cut and then going back and redo the engraving to the full depth of cut I need. Still willing to try and the automotive paint and see if there is some improvements.
  1. Milling / Drilling painted aluminum
    By V42bis in forum MetalWork Discussion
    Last Post: 06-07-2013, 04:11 PM
  2. Looking for an engraving and painting machine
    By mswmws in forum Uncategorised MetalWorking Machines
    Last Post: 11-07-2012, 10:11 AM
  3. Aluminum Spray Painting
    By Pysiek in forum Material Machining Solutions
    Last Post: 08-16-2012, 03:38 AM
  4. Best place to get painted aluminum engraving stock
    By spoiledbrat in forum Engraving Machines
    Last Post: 07-04-2007, 07:56 AM
